full use of multicore processor
full use of multicore processor......
86 Comments
sam_m
Add "GPU processing support as/when suitable" to this.
e.g. Use the GPU (CUDA) to assist with rendering and FEA.
Can't imagine you would want to use the GPU to aid with calculations during normal modelling for fear of nuking frame-rate, but, saying that, those with multiple GPUs or Telsa cards might be able to benefit (if multi-core is already supported).
smithar
smithar
I'm all for it, but file this under "Start from scratch".  All these CAD packages are kluges from waaaay backSmiley Frustrated
dan_szymanski
This is definitely one of those "start from scratch" ideas.  Using tesla cards/cuda processors is still viable.  Some people have already found success with one powerful workstation card for graphics and a second affordable card for physics in the gaming world.
S-Barbieri
really don't understanding the reason why with inventor my processor is always "8%" used even if i'm loading a big assebly for mintues..
Rdegreef
By loading an big or complex assembly use the multicore processor.
Right now he's never using more than 25% but it take minutes to load.
dgorsman
Duplicate of this idea: http://forums.autodesk.com/t5/inventor-ideastation/full-use-of-multicore-processor/idi-p/3744575
I should point out that not all operations can be split out to run in parallel with each other.  At a very basic level, when an operation is dependant on data which is derived from another operation, which itself is derived from the result of several other operations, there is no way to run them at the same time.
Consider the opening of a large assembly. From what I can see in terms of file usage and CPU usage it seems to be a very linear-sequential process and file I/O speeds are very low. Consider opening the assembly on one CPU core then open subsequent parts on other CPU cores to speed the whole process up.  The same can be done for Saving.
Many parts of Inventor do use multiple processors now - FEA, Studio and many other operations. This also applies to Vault - certain operations take advantage of multiple processors. Autodesk continues to add as they go.
In the attached image, I was updating my assembly model - as you can see it was using everything.
We also need full processor usage while using cable and harness as well.
Do you realy think that they gone rebuild the software if they can fiddel a bit with small ajustments and collect the loot every year when they bring out a"new" version.
this company is not a sofwaere company it is a sofisticated monney pumping system.
You will have the same **** evrey year an they yachts wil be a few feets longer.
For the rest they dont give a tos.Smiley Happy
DRoam
So this is obviously at the top of the wishlist for a good portion of the Inventor community....
Is it at the top of Autodesk's list? Or even on the list? It'd be nice to know...
DRoam
Well, Autodesk? Can we hear from you?
dusan.naus.trz
Hi all,
I want too full use of multicore processor, and also use multiple graphics cards
Yep
multi core and a few tesla card for the reel fun.
hey Autodesk do we have to wait for quantum computing before you moveSmiley Very Happy
francis
freierfall01
allso full gpu use 🙂
brett.holmes
Can I click this more than once!!
Nastran in-CAD also needs it badly, it will only use 2 cores at once which makes larger simulations go much longer than they should
I've now got a z800 HP workstation with 2x xeon processors. Bit of a shame that it only uses 1 out of the 8 cores, meaning this expensive setup is pretty useless for inventor. Imagine a world where inventor is 8 times faster then nowadays, would be heaven right?
Technology Administrators
