Fix the Bend command
When we try to bends a part 360 degrees with the wright values we sometimes a gap between opposite edges, but you do this easily in 3ds max.
6 Comments
Yijiang.Cai
@tedod13202 Now Inventor supports bend part command using 360 deg, but not supported for sheet metal fold using the angle >180 deg. I suppose you are requesting about sheet metal fold. Could you please double confirm it? Thank you!
debason480
Community Visitor
Hi, the reference line must have interference with the body to apply the command. Why you don't show a warning box when the line and the body haven't interference? some beginner users don't know this.
Yijiang.Cai
Hi @debason480, I suppose you are talking anonther enhancement request about sheet metal fold command, which is tracked as [INVGEN-68534]. Thanks!
Hochenauer
Depending on the unfold method we could allow angles >180 degrees. Bend deduction and bend tables  is only up to 180.
we would limit at <360 as we need to guarantee a seam.
copej42850
Community Visitor
Hi, when trying bend an object 360° this issue is present sometimes. Thanks!
havefej523
Community Visitor
This issue exist also in part design, it's a little gap.
