Fix existing issues with Frame Generator G_L not updating
There has been a known issue with Frame Generator since 2011 or so, where the G_L parameter provides incorrect lengths in certain situations, which can lead to costly errors. This idea is for the development team to simply address these issues.
Related links:
http://forums.autodesk.com/t5/inventor-forum/frame-generator-members-rotated-45-degrees-g-l-won-t-up...
http://beinginventive.typepad.com/being-inventive/2011/06/double-mitered-frames-report-the-wrong-fra...
http://forums.autodesk.com/t5/inventor-general-discussion/g-l-frame-generator-param-loose-driven-dim...
3 Comments
dan_szymanski
Status changed to: Accepted
Accepted idea [412]. Thanks!
dan_szymanski
This idea has been implemented within Autodesk Inventor 2019. Special thanks to everyone who cast a vote for it.
jingyi.liu
Here is a screencast video to show the improvement.
