So I have been a long time SolidWorks user, and there was one tool that was quite genious and a huge time saver. It's called 'Fill Pattern' and it fills an area with, well, a pattern. It looks a little bit like this:
![ewoudvanduijn_0-1664871540281.png ewoudvanduijn_0-1664871540281.png](https://forums.autodesk.com/t5/image/serverpage/image-id/1123118i12BDE2CCB8A363E1/image-size/medium?v=v2&px=400)
You select an area to be filled, than define your seed geometry (there are some base forms but you can prepare your own feature like for example a slot). Than you set an offset from the borders of the area and BOOM you're finished.
With just a single operation you have a nicely filled piece of sheet. It is also way faster than the the linear and circular pattern operations, since on heavy patterns it only generates the instances it actually needs.
You can even create a split plane in the back of your plate to constrain the fill area even further.
There are a lot off things that Inventor really does better in my opinion, but this is a tool that I kind of miss.
If the Inventor team can implement something like this, i'd be a happy engineer :).
