Dear all, …..
In extrusion between two planes, a result is obtained when the extrusion surface is between or outside the planes. However, if the parameters are changed so that the extrusion surface lies between and outside the planes, an error message will appear because the program is unable to extrude part of the surface to the left and part to the right. Please change the function so that the cutting axis and the directions of the extrusions are recognized and the extrusion is carried out. Thank you.
