Extrude an overlap closed area in a sketch
There are quite a few ideas for closed loop extrudes or identifying whether they are closed or not. However I couldn't see any asking for this, if I create a really simple sketch of two overlapping rectangles:
It is impossible to simply pick the overlap area, which is effectively a closed profile and extrude/revolve:
The only way appears to be splitting the sketch geometry, which then allows you select the overlap area as closed boundary:
This seems like extra steps, which you shouldn't need to make and other applications do not require you to split!
9 Comments
symayl
草图中,绘制几条线段相交,做特征时不默认为封闭轮廓,需要在相交线段上加点才可,详看附件
DRoam
Related idea: Circular Array in sketch. See my comment here.
ceflamarion
In English please. If not we may not analyse and vote on it. Thks.
jingyi.liu
Hi @symayl
如大家的评论,如果希望得到更多人的支持,建议使用英文来提交,或者你可以把你的需求发送给我们(发送信息给你)。在你提交的需求中,在Inventor Idea 中有类似的帖子,请参考。 有用户注意到Fusion 360中支持更好地判别封闭的轮廓,你可以去支持下面的帖子 https://forums.autodesk.com/t5/inventor-ideas/show-closed-geometry-like-fusion/idi-p/6862835
@DRoam and @ceflamarion
The submitter request for better detection of closed sketch profile. In author attached snapshots, Inventor can't detect the closed profile unless add intersection points manually. Right now, Fusion support it very well, so I suggested the author to cast votes to below idea.
Jingyi
PaulMunford
You can also place a point on each intersection to help inventor find the intersecting loops.
symayl
 Several lines are intersected
in the sketch (Figure 1). When a feature line is made, a few lines are unclosed by default. It is necessary to create points on the intersection line segments to choose (Figure 2).
Please look at the attachments!3Q
symayl
@PaulMunford,Bingo,But it's obvious that it's smart enough.
Rkov
I have used NX before, which offers a multitude of methods of selecting your region. I am surprised at how poorly Inventor does this.
Naturally, any two lines that cross, is an intersection. There should be no need to actively put a "point" where lines intersect. In addition, I have often struggled with complex geometries where "points" do not help.  Even if my geometry is 100% symmetric (lines, points, intersection, etc), Inventor still does not correctly select regions in the two perfectly symmetrical halves. I then have to spend a lot of time gradually destroying my sketch, by trimming away parts of the sketch.
The bottom line is; where two lines or curves (circles etc) meet or cross, that is a "point", and base for a new region.
jingyi.liu
This request has been implemented without extra points added to the intersection, refer to the below snapshot.
