Expose Options 'Outline' and 'Strokes' in MARK command. Inventor 2023
In this new command there are two options in Style Library that control the behaviour and the result of this feature.
These options are in the Style Library and depends of the method you can choose using it.
In my opinion  will be better if will be implement a drop down menu in the pane of the command to set it indipendent of the method (surface or through). So, it can't be a Style, in this way the user can freely choose the result needed.
