Inventor needs an expanded Match Properties function that goes way beyond the current ability to match properties on dimensions only. It should apply to lines, hatches, blocks, everything in the sketch environment. It should be similar to the Mechanical Match Properties that can match common properties between numerous different elements. Inventor is very cumbersome compared to its cad counterparts. SLOW and tedious matching is the current state of workflow.
