Enable visibility setting for folder/component pattern in drawing file.
We can set visibility for folder/component pattern in assembly file but not for drawing file.
User wants to be able to change visibility for folder/component pattern in drawing file as well.
2 Comments
nickada
I made a proposal to be able to use iProperties to assign a layer property to a part or assembly so you could then turn the visibility of those parts and/or assemblies on or off in the drawing.
whinkle
I would extend that concept to also allowing visibility setting for entire pattern ELEMENTS in a drawing view, in addition to allowing it for the entire pattern.  This as pattern elements can comprise multiple components, just necessarily just one.
