Enable set visibility for each sketch element
Currently, Inventor can set visibility for entire sketch from Object Visibility.
But not for each element, for example, set invisible for sketch "point" only.
A few CAD system other than Inventor seem to have the filter for visibility such as above. It could be improvement for visibility and operability if the detail filter for visibility will be available, my customer thinks.
3 Comments
JamesLodge01
I think it would be a good Idea to add a filter for construction sketches.
This way you can add construction sketches and turn thevisability on and off when needed.
Tags (2)
BearsFan
I wish there was an option to right click and turn off construction lines from a sketch.  Similar to how it works for Dimension visibility.
zhangyua
wish that controlling construction line visibility like controlling it in AutoCAD.    In AutoCAD, we draw via construction lines, when we finished, we can close all the construction lines.
