Enable Copy/Paste in "Edit with Frame Generator" dialog
Currently one cannot paste into any of the dimension fields when editing a frame member. Fields affected are circled below. This makes editing very tedious when one must manually type in a long dimension.
2 Comments
inv.ideareview
@evankaspar, could you have some more comments or video about the workflow you copy/paste the dimensions in the dialog? Do you want to copy the orientation dimensions from another FG member? Or any other workflow?
inv.ideareview
Status changed to: Archived
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know.
- Inventor product team (Inv.idea review)
