It would be useful to be able to edit view representations from within a drawing view.
Currently if you try to change the visibility of a part in an associated view it is just greyed out.
I would like to be able to select parts in the drawing tree, or using part priority in the view, and change their visibility and expect a similar prompt (see below) that comes up in when changing visibilities in the assembly environment. i.e. would you like to modify the view rep or remove the drawing view's associativity.
It is painful to have to go back to the assembly environment and find the part there when it could be this easy.
Thanks!
