Drawings: Be able to drag dimensions without exiting dimension command
It's annoying having to exit the dimension command to drag and re-arrange dimensions. This should be part of the dimensioning process. We should be able to create new dimensions, drag existing ones to a better location, and then continue adding new dimensions without escaping and re-starting the Dimension command over and over.
2 Comments
DRoam
It would also be nice to be able window- or Ctrl-select multiple dimensions for dragging. Right now if we single-click a dimension while in the dimension command it goes to the dimension edit box. I personally never use this, and would much rather be able to multi-select and drag dimensions while dimensioning. If I want to edit a dimension, I'll double-click it like always. Thoughts from other users regarding this would be helpful. Thanks!
zdzislaw
I use Ctrl button to organize dimensions.
A bigger problem for me is when for some unknown for me reasons distances between dimensions are different.
