Change DWF warning upon Check in from Express mode
I have just recently been able to migrate everything to 2018.
With the improvements to the Express workflow, I find myself working in express mode much more than in the past. As a result, I end up checking in files from the express state.
Every time I do this, this box pops up:
Several Issues with this box:
  1. I have automatic DWF creation during Check-In disabled globally, so I should not be seeing this at all
  2. There should be a way to disable this prompt so it does not show every time, so I do not have to look at it and click
4 Comments
ChrisMitchell01
Seems more like a bug to me - I'll forward on for investigation.
cmcconnell
Thanks Chris!
rachel_li
Hello, @cmcconnell
For the first issue, where do you set the automatic DWF creation during Check-In disabled globally? Is it in the Settings of Check In dialog? The message will not prompt when I turn off the option to create visualization attachment. I'm using Inventor 2018 + Vault 2018. DWF_Option.png
Rachel
cmcconnell
I have it unchecked In the vault settings. Under "define visualization attachment options".
