Drawing Revision Table Re-Sequence Alpha / Numeric
Please can you add the ability to re-sequence the drawing revision table lettering / numbering without having to delete the original revision table and add a new one.
On occasions, for whatever reason, the sequence jumps. I have a drawing with revision A, B and C in the table, for some inexplicable reason it then jumps to revision F or similar instead of D.
It would be great if this order could be reset / continued somehow, a bit like the 'start numbering at / continue bullet numbering from' option in Microsoft Word.
Many thanks,
Gareth 😀
