It would be great to be able to have a point to point (between 2 clicks) dimenension tool when doing layouts simlar to the dimension tool in AutoCad. It is particularly problematic when trying to dimension from a line to a curve to indicate clearance. The dimension tool only want to dimension to end points or radius. Nothing seems more frustrating than having a drawing and not being able to snap the dimension you need.
Currently to dimension between a line and the middle of an arc I have to draw a sketch, on my view project the curve I want and then draw an arc over the top of it that stops where I want my dimension.
