In this example there are two flexible assembly of the same instance. In the two pipe elbows below when dragged it is difficult to locate the exact rotation needed if you are looking to swing one elbow only. It would be great to have a selection on each elbow that you would not want to rotate or not.
In this example it shows only one piece rotating and it depends where you select it.
Most of the time when selected and dragged about both elbows will move and difficult to re-position.
When trying to use the flexible drag both elbow move and there is no clear direction to which you can manipulate it back.
Thank you,
Don
