Design Accelerator - Gear rack
There should be a new kind of design accelerator or possibility inside the spur gear accelerator to design gear racks. It would speed up the design and is kind of missing, if i'm not mistaken.
13 Comments
Subject says it all
ca-d.one
Here is the picture
Translation via Google Translate
Original Post:
Gestell Generator
Hier nun das Bild
I have never understood why this feature was omitted from gear generation, it makes no sense to me whatsoever. Its as if the creators of the gear generator have never heard of a rack and pinion. I have mentioned this before to the development teams, and just brought it up again in the Shelby forum. I have always recevied the same answer, that other things have higher priorities. That may be so, but when you have personally wasted time creating your own involute curves to create a rack the lack of an automated feature suddenly becomes extremely annoying, and expensive in both time and money. One thing for sure guys, don't expect to get this facility anytime soon!
[bump]
Any news on the Rack and Pinion Design Accelerator/Calculator ?
al_inventor
Design options to accelerating gear design, the addition of a rack and pinion design features, I think it would be useful. SW be doing it against our opponent, we are launching the competition 1-0. Rack is not welcomed by users do a lot for the design process. When the gear rack can be added creation options?
Best Regards.
Ali Osman GÜLER
Tags (2)
I think it would be useful to be able to design/draw a rack to match any pinion drawn.  It is simple enough to design the pinion however there is no fascility to create the rack other than to draw the component "long hand"
dusan.naus.trz
possibility as the picture
sample Example: https://www.youtube.com/watch?v=2PR_ByClOM0
jacek_stirba
New generator Inventor should be better than the video from ST8
JamesLodge01
Personally, I still can't believe that this functionality is not available.
Inventor gear generator has 3 konfigurations,
1-spur gear generator
2-worm ger generator
3-bewel gear generator
Tags (1)
ca-d.one
It would be really great to have a rack gear generator in Inventor.
Tags (1)
jingyi.liu
Hi
Please cast your vote to below idea which is identical with yours.
https://forums.autodesk.com/t5/inventor-ideas/add-rack-amp-pinion-to-the-design-accellerator/idi-p/4...
Jingyi
coooooooooooooooooooooooooooooooool
