Customizable Spline Generator
I would like the spline generator to be customizable.
As it is now your out of luck if the spline you need is not in there.
For example, I created a 3D model from an old 2D drawing that has all the spline information on the print and could not find a match for the spline in the spline generator. I needed a 78 tooth spline and a 79 tooth was the closest match.
I would like to have the option to be able to plug in more spline data if needed.
Brent
1 Comment
dax329
I would also like the ability to modify dimensions and have the other ratios automatically update. For instance, machining a part before heat-treat expansion to set the appropriate major/minor/tooth/space parameters.
