Hello dear Autodesk team,
it would simplify the plan derivation process significantly,  if you can also use your own views, which you have defined in the part or assembly, in the drawing.
 here you can see custom 3D section in assembly
here you can see custom 3D section in assembly here you can see that that the custom view will not accepted for drawings
