Create In-Place Component templates
Im not sure whether my settings is off somehow, but i've noticed that i am in a metric assembly, and i create a component with Create In-Place Component function, by default it chooses Standard.ipt template, which is not metric, and in order to change that, you have to browse templates and chose the metric one manually. It would be nice if by default it would recognize/detect which template you are working on and choose it by default as it is in your assembly.
A minor problem, but sometimes when in hurry, you dont notice it and only recognize it when you start drawing sketches and dimensions comes as inches instead of millimeters, and then you have to change it through the Document settings > Units..
While in Metric Assembly Standard(mm).iam
Creating in-place component, default templates.
To change it, you have to browse templates> go to metric> and choose > Standard (mm).ipt.
