Coping with Frame Gennerator
I use frame generator a lot.  We us a variety of round and rectangular tubes.  It would be great to be able to cope around a round tube mid-member.  It would be great if there was a modified version of the Notch tool where you could select the member to get coped, select the member to get coped around, input the depth of the cope or use machine handbook standards.  My current process is:
1)      Edit the member that is getting coping to, and create a work plane tangent to the member parallel to the proper origin plane
2)      Return to frame
3)      Under the Design tab - Enter Trim/Extend tool
4)      Select member(s) to that will be getting coped
5)      Click the “Face” button and select the work plane that was previously created
6)      Enter the depth of the cope
7)      Click apply
8)      Under the Design tab - Enter Notch tool
9)      Select member to get coped
10)   Select the member to get coped around
11)   Click apply
5 Comments
jamesc
Frame generator is an amazing tool, but it would be great to be able to cope around a round tube mid-member.  It would be great if there was a modified version of the Notch tool where you could select the member to get coped, select the member to get coped around, imput the depth of the cope or use macine handbook standards.  My current proccess is:
2)      Return to frame
7)      Click apply
11)   Click apply
Tags (2)
jamesc
inv.ideareview
Hi
Thanks for your feedback, you have posted this idea for several years, noticed your request is similar to below one which has been accepted. Could you help to verify? In you case, if Inventor enhance notch feature, then you needn't create the workplane to trim the pipe before notching.
https://forums.autodesk.com/t5/inventor-ideas/notch-feature-option-for-laser-cutting/idi-p/4967764
https://forums.autodesk.com/t5/inventor-ideas/frame-generator-notch-with-a-gap/idi-p/3698722
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
