control / customize Document Tabs Text
I would like to be able to customize document tab text.
According to this solution by Phillippe Leefsma back in Inventor 2013 this option was not available. To my current researches with the current development stage of Inventor this is still not possible.
[BACKGROUND]
Modern PDM systems need more and more to be in the condition to govern the filename, in order to grant the filename uniqueness. In certain scenarios this information is not relevant to the designer, who would need to click each tab to find the document he wants to bring in foreground:
current statuscurrent statusCustomizing more precisely what is displayed on the document tab of each open document, as it is already happening with the DisplayName in the browser, would fill the current gap:
desired functionalitydesired functionality
11 Comments
MistakenEngineer
Good idea.
Also, @Anonymous, one of the easiest ways to implement this is to simply link the DisplayName property to the text at the bottom because you can already change the display name. However, currently, it only affects what is said at the top of the application and not at the bottom where he is talking about.
petr_vonasek
We are solving the same issue. Our customer uses PDM called Easy PLM. File names and Drawing numbers are two separate properties. For the user’s orientation would be useful if the PDM system was able to govern also the text in the file tabs (like in the model tree and file window).
@freesbee good idea using Vault or any other PDM/PLM system!
What PDM / PLM system are you referring to "Easy PLM".
Where does it come from, do you have a provider?
I am curious about the usability of it for us!
freesbee
@petr_vonasek
indeed: filenames and document numbers are OFTEN different properties
@bradeneuropeArthur
I suspect your question is more for Petr, as I am confident with few different PDM systems (PSP, Meridian, GAIN Collaboration) but I have no idea of "Easy PLM".
petr_vonasek
Hi Arthur. You can find the provider here: https://td-is.cz/ + product description here: https://td-is.cz/plm-sprava-dokumentace/
Easy PLM is well known especially in the Czech Republic, but it is used also abroad (South Corea, Germany, UK) in its localised versions. It has integrations for all major CAD systems and it is based on configurable workflow.
There is also an extension Easy Technology (=ERP, system for production planning), which can cooperate with Easy PLM and could be intergrated with some economic systems.
It would be comfortable if the names of the tab in Invenort can be adjusted.
el_jefe_de_steak
I agree. This tab should show the display name of the document instead of the file name.
You can change the display name via the API (thisDoc.Document.DisplayName).
guido_overath
Mh, at my company we are dealing with large assemblies 5000 to 80000 parts. No one need to know the document number or Drawing number except the number of some main assemblies. We use classification to search for a specific component, then the structure is shown in ERP/PLM and one can start at the right level.
Ok - in our environment we use running (sequence numbering) numbers. In case of a drawing is needed the same number for 3D component and the depending 2D drawing is given by the ERP/PLM
herzogh
Idea added to our backlog for future consideration [INVGEN-74686]. Thanks!
dan_szymanski
Status changed to: Accepted
Accepted idea [INVGEN-74686]. Thanks!
Yijiang.Cai
This idea has been implemented within Autodesk Inventor 2027.1. Please review the Inventor 2027.1 What's New article here. For more information regarding how you may leverage the feature, and please review this page. Special thanks to everyone who cast a vote for it.
