Connect part in assembly for Sketch Driven - Maschining
Look at the video link
For Bolted Connection, parts and next assembly
I did frame structure. I did hole with function pattern. I put the assembly frame structure into the next assembly. I put the screw and then I wanted to use the pattern assembly of the frame structure for screw it did not work.
Assembly contains sketch pattern formed by machining. This assembly is inserted into another assembly that will put the mounting bolts or other components that want to tap into the array of holes and you can not. If I made a hole in the parts and used field sketches and works connecting bolts in the report but it does not work for machining.
Bolted Connection in assembly can not be moved, demote and promote
https://www.youtube.com/watch?v=F6gED-G8oQY
https://www.youtube.com/watch?v=y-n2Damos_E
https://www.youtube.com/watch?v=VjayjJtv6UI
https://www.youtube.com/watch?v=Cb6ip-uH4N4
https://www.youtube.com/watch?v=zRjCOjEVe20
5 Comments
hynek_raszka2
Thumbs up, nice Idea
Yijiang.Cai
Status changed to: Accepted
Many thanks for posting the idea, and tracked as [INVGEN-74200]
Yijiang.Cai
Yijiang.Cai
dan_szymanski
This idea has been implemented within Autodesk Inventor 2026. Please review the Inventor 2026 What's New article here, for more information regarding how you may leverage it. Special thanks to everyone who cast a vote for this capability.
