Chamfer Length
Chamfer Length
The chamfer command should give us the option to put in how long we want the chamfer instead of assuming that we want the chamfer to go the entire length of the part.
17 Comments
dan_butler_komatsu
Great idea, I have thought of this many times!
SerkanCicek
Chamfer Edge Offset
I also have this problem with concrete floor slabs that need a chamfer all round except where two panels join together at one edge.  I've found a work around but it is not very elegant.
Karl_K
Working with parts that are made out of steel, needs also that kind of feature where i don't need to chamfer the total length.
Like that idea!
Great idea
Please can we have this asap!
dan_szymanski
Status changed to: Accepted
Accepted idea [US-128723]. Thanks!
DRoam
@dan_szymanski, I know only chamfers are mentioned in this thread, but are fillets by close relation included in the Accepted idea? (see this request: extention limits for fillet)
dan_szymanski
@DRoam, I recognize these two features are close relatives, however to Developers they are seperate areas of code.  As such, they are tracked as seperate requests.  As such, it would be good to get some more votes attached to the aforementioned Idea.  Our bigger request in the area of Fillets is currently: Add a "Negative" radius for clearance.  Thanks! -Dan
DRoam
Ok, thanks for the info!
In that case, for any who would like to see the same "defined length" functionality added for fillets, please consider giving a vote to this Idea: extention limits for fillet
dan_szymanski
This idea has been implemented within Autodesk Inventor 2018. Special thanks to everyone who cast a vote for it.
JBerns
I've discovered that you cannot pattern a partial length chamfer feature. Would patterning this feature be of value to others?
Jerry
dan_szymanski
Hi @JBerns,
That might warrant a separate Idea since we never supported patterning for single edge chamfers.  Patterning a partial chamfer makes a lot more sense to me.  Simply my 2 cents.  Thanks.  -Dan
DRoam
Chamfers can't be patterned or mirrored, but fillets can. This idea would get us on the right track to fix that inconsistency (as well as several others), and pave the way for a lot of extra powerful functionality, too: Combine the fillet and chamfer tools.
JBerns
Autodesk,
Thanks for adding Partial Chamfers. Could you please allow the dialog box to be resized? It is inconvenient to use scroll to see all the columns. The resized column widths are reset when you next use the command.
Jerry
jeanie.wayker
See here for more info: What's New 2018 Chamfer
