Chain Pattern
Chain Pattern
Chain Component Pattern. Please see the picture and video link. If you like Idea, then vote.
https://www.youtube.com/watch?v=KrEIHjZ3Qgs
https://www.youtube.com/watch?v=etEZEP4Lkk0
6 Comments
dusan.naus.trz
sergio.missori
In Inventor this is already possible using pattern along a curve. Not so simple to use but it works well.
dusan.naus.trz
RobertoRJFaria
@sergio.missori, you can pattern along a path in a part context, not in assembly as it's shown in the video, in Inventor there's simply no way this is feasible. This Solidworks feature is amazing and it's something that should be added.
osmo_suomivirta
Community Visitor
Pattern along curve cannot be used with chains. Chain doesn’t follow curve arc, path is distributed as straight lines with length of chain pitch. So actual chain route is shorter than the one made with arcs. You can check this by doing so. Are chain links cocentric in sprocket arcs? No they’re not.
nick_panzarino
This would be a welcome feature! Energy chains are everywhere in industrial applications, and Inventor currently has NO native way to model them accurately!
Flexible chain, not driven - Autodesk Community
Correctly modeling a dynamic cable carrier - Autodesk Community
