Center Mark - Multi-select align with edge
The below picutre shows a problem, where in an Inventor drawing when mutliple center marks are selected, the "Align to Edge" command only modifys one center mark and not all of the selected.
A user who has many center marks in their drawing must manually align them one by one, which would be time consuming, so it would be great if multiple center marks could be selected and aligned with one click.
7 Comments
Well drat... I didn't even realize you could do that at all!  Thanks. 🙂
LeanderTorres
Hi there,
Just use the centerline command, gets you there faster.
SteveMDennis
Status changed to: Accepted
Accepted idea as [US-55205] Thanks
That's all well and good, but I often have bunches of holes that align with an edge but not each other, in other words they do not share a common centerline parallel to the edge in question.
And what if I don't want to show a centerline connecting all my holes that just happen to line up?
Is there iLogic that can help me select multiple center marks and apply an alignment to a selected edge?
ChrisMitchell01
This idea has been implemented within Autodesk Inventor 2017R2. Special thanks to everyone who cast a vote for it
jeanie.wayker
SER4
But you forgot to also include the multi-select "Extension Lines"!
