It is currently not possible to replace the model reference in a nailboard drawing.
The reasons I want to replace nailboard drawing references:
- Reuse drawings for similar harnesses
- Use revised models for revised drawings.
- Seperate nailboards from upper level assembly drawing.
* Make original harness in upper level assembly.
* Use original harness to create a nailboard.
* Make original harness unadaptive to prevent trivial changes in length in case upper level assembly changes slightly
* Copy harness to upper level assembly, and make adaptive (thereby creating a new model.)
* Modify routing of copied harness in upper level assembly without having trivial changes in length to nailboard drawing.
*** Nailboard cannot be revised now***Turning adaptivity off for the original harness renders future updates non-associative to nailboard. Because, turning adaptivity back on creates a new model, and the nailboard cannot update the nailboard model reference.***
