Show only
Search instead for
I would like to see the minimize button return. I do like the arrange button but there are times I like to minimize some of the screen so that when I arrange the windows only the active screens tile.
And what about the "Neither minimize nor maximize"-button???
Occasionally I would like to choose a good aspect ratio for a Bitmap export. Still not possible any more (except for adjusting the entire Application-Window)
Why do modern developers always declare things as superfluous, which their predecessors have invented for good reasons? This is so hubristic!
Though not quite as easy as with the previous window button for this specific workflow. The easiest way to do this now is by dragging the document tab out. The document frame window can then be resized by itself. Then when done you can drag the tab back to your desired location.
