Appreciated Inventor team!
It would be a really good feature, to add the possibilety of an editable starting point for the borehole tool, like it is possible for the extrusion tool with the "from-to" selection.
I am often facing moments, where I have to create severeal countersunk boreholes in the same axis on different levels.
So up to now, it is only possibel to project to borepoint on the surface where the countersunk starts, which can create a lot of CPU load and time when you work with several boreponits and model states.
Currently this is only possible with the screw connetion tool in assemblies.
It would be a major benefit and safe a lot of time, if it would work for multisolid parts as well!!!!
Thanks in advance!!
