BIM - Inventor part always vertical in Revit
A wish regarding the export functionality from Inventor to Revit.
The wish is to get more possibilities when exporting the part to Revit.
As an example, the element is set to be always vertical in Revit as standard, when using the BIM function in Inventor.
This is a function that can be changed inside the Revit family afterwards, but then the client has to edit the family and change this function. The wish is therefore that this could be set inside Inventor when you export. Because it is the people that create this part, that knows if the part can be workplane/faced based or not.
1 Comment
dan_szymanski
This idea has been implemented within Autodesk Inventor 2026. Please review the Inventor 2026 What's New article here, for more information regarding how you may leverage it. Special thanks to everyone who cast a vote for this capability.
