Better way to identify fittings thickness (schedule) in tube & pipe style
In T&P style the schedule of the fittings (Elbows) are not applied  according to what we set in below window.
By default its chooses the smallest thickness available. This should not be the case.
Also, the list should be mentioning the schedule number not the thickness. We have to open the pipe chart to check which thickness corresponds to the schedule.
1 Comment
A.Acheson
I have confirmed that the OD/ID Schedule only controls the pipe and not the fittings. There is no label or tool tip on that listbox so the user wrongfully assumes it is changing the schedule for all items connected with that style.  So if you select a SCH 160 pipe and even thou a SCH160 elbow is available it is not chosen. The user has to manually select the schedule. Maybe there needs to be an automated selection out of the box and a manual overide-chek box if someone wants to mismatch a fitting to pipe schedule.
Technology Administrators
