Backwards function in Text command (Sketch)
Sometimes when we need to engrave a text on a surface, depending on the position of the solid, this happens:
For this type of situation it would be interesting to have a Backward function in the Text command, as it already exists in AutoCAD:
The part used in the image is attached for better understanding
Best Regards
Jorge Luís de Andrade
4 Comments
PaulMunford
Are you saying that you DONT want the text to be backwards? If so - could you try flipping the workplanes normal direction?
sergio.missori
I agree with PaulMunford: The color of the plane is there just to understand which is its positive normal direction.
Hello PaulMunford and sergio.missori
I did not know this normal flip function, thank you all for the help.
This really helped me.
When the sketch is done in the plane we can use the "Flip Normal" function.
But when the drawing is done on a face of the piece, and for some specific reason the user needs the text to be backwards. Imagine someone designing a Seal/Stamp (I was asked about this today by a customer).
