Any iProperty in browser
Hi All,
Ive been looking for a way of showing the parts description in the browser instead of the part number/file name. This would make a good addition to any new releases,
Sorry if this has been asked before.
42 Comments
dan_szymanski
Status changed to: Gathering Support
Jhunt, I am updating this Idea as a duplicate of http://forums.autodesk.com/t5/Inventor-IdeaStation/Any-iProperty-in-browser/idi-p/4833615 and accepting the other as the Master (due to the current kudo count). Despite the fact this Idea was authored first (in 11-7-2012). I see you have also replied to it with comments. I hope you are cool with that & understand. Thanks -Dan
dan_szymanski
Status changed to: Accepted
Accepted idea [419]. Thanks!
 I have the same wish: We use dumb partnumber (which is also the filename) without any information in it. Therefore we would like seeing also the description (i.e. a certain iProperty field) in the Browser (besite the filename).
Many thanks in advance.
Wim
dan.szymanski
Any idea when this will be implimented?  I could really use it now.
Thanks for making this happen,
David
Tilman.K
We are very interested in this function and hope to find it soon 🙂
Regards
Tilman
nwrensch
I am also 100% for a width mate, I used it continuosly in solidworks, but sadly I am not using Solid works right now. I am getting used to Inventor, but I realy miss the width mate.
BjornAndersson
When using the "Rename Browser Nodes" the options are very limited.
A nice way to keep order and organize files is to name files with part numbers. Since the two options for browser nodes are filename and part number, there is actually only one option for many users.
A suggestion is to have the standard iProperties as an option for browser nodes, and also to combine these using like regular expressions or something like that.
Tags (2)
DRoam
It would also be nice if the browser nodes stayed synced to what we set them to. For example, if we set them to Part Number, and the Part Number changed, the Browser node would change as well.
xzenter
Often the part number and file name are the same and to find in the browser the right part is very difficult if the details are very much.
DRoam
@dan_szymanski
Duplicates:
Also, this thread is very hard to follow with all of the misplaced comments regarding a width/symmetrical mate. Can those be deleted or moved to the right place?
dan_szymanski
Thanks @DRoam, they have been moved & the votes merged into the Master Idea. As far as deleting comments, I typically shy away from this action. Deleting comments in a forum can be sensitive business, especially ones that were authored for constructive purposes. Thanks!
DRoam
I understand. Thanks!
bindlmi
it would be nice, if i can use my user defined iproperties to overwrite the browser nodes in my assembly. For example, I have an iProperty called "ARTICELNUMBER" = 123456789 and another one called "NAME" = "Plate1" - the new Browsernode could be "123456789 - Plate1" (all my choosen iproperties seperated by " - ")
We got some iProperties, that we like to see at browser tree. Actually we got a marcro that renames the browser nodes, but it would be easier to trigger an inventor command 🙂
Best regards
Michael
Tags (3)
dan_szymanski
We are refining procedures around idea status.  Changing this to Future Consideration.
mtmarchant
By default, Inventor has the "Rename Browser Nodes" functionality, however it is limited in that you can only rename the nodes based on the Filename, Part Number, or the default option (which is also the filename, so that seems redundant). In my experience, it would be helpful to be able to rename the browser nodes based on any given iProperty value (i.e. description, stock number, vendor, etc.). Custom iProperties could potentially be useful, too, to other users. At my company, we utilize the description iProperty to quickly navigate through the browser on our larger assemblies, but for this to even work we had to implement an iLogic rule, as well as an Event Trigger to automatically implement this. Thankfully, some helpful folks on the forums gave us an iLogic rule that does this, but since the Rename Browser Nodes functionality already exists, and iProperties can be referenced, why could this functionality not be broadened to allow renaming of browser nodes based on a part's given iProperty?
c.kolb
Especially because the function already exists in the Vault Browser.
For users who have only the part number as file name, this is an extremely important function!
dg2405
How is the status of this idea? When will Autodesk implement this to inventor? This is a confusing thing since i work with this program!
@dan_szymanski: I want to ask about the status of this feature. The initial idea is there already from 2014 and it would be a highly appreciated function!
J.VandeMerckt
Hi Inventor users,
Currently, the default setting in Inventor displays the file name as the part or assembly name in the Browser tree. Although this can be changed manually by renaming it directly in the Browser, this is a time-consuming and repetitive process, especially for large assemblies (example shown in the image below).
In our system, we use "dumb" part numbers as file names, which means the displayed names in the Browser offer no meaningful information about the part. However, we have other properties, such as Inventor Properties or Custom iProperties, that provide a much clearer description of the file's purpose or content.
Proposal:
If Inventor could allow us to link the display name to an Inventor Property or Custom iProperty, it would give users much more control over the information shown, making it easier to identify and work with files. Especially with companies who work with a structured file naming system.
This feature would streamline workflows, save time, and make the Browser tree more informative without manual renaming.
Best regards to all
Justin
Maxim-CADman77
Another useful option would be to 'stabilize' browser node names In order to prepare the iLogic-configured assy model for any Copy/Place iLogic Component etc scenario.
