Allow text box resize when text is rotated
In a drawing sketch, I created a text object.
Using the Rotate tool, I rotated the text object 90 degrees.
Afterward, I discovered that you cannot use the grips to resize the text box.
I repeated the sketch text creation process and this time chose rotation in the Text Edit dialog.
Still cannot edit the textbox size using the grips. Only move is supported.
A non-rotated textbox has grip editing available. Note the double-arrow cursor in the image to resize object.
A rotated textbox does not allow editing. Note the default cursor in the image to move object.
Even rotating the textbox back to 0 degrees or a normal orientation fails to enable the grips - resizing is disabled.
I tested this in 2022, 2023, and 2024.
Please allow textbox editing for text objects created in drawing sketches regardless of rotation.
Jerry
1 Comment
Yijiang.Cai
Many thanks for posting the idea, and tracked as [INVGEN-77279]
