Allow RMB menu acces when using functions like constraint, joint, hole etc.
When using the constraint I often want to toggle visibility to acces a certain face,point, or part. right now you have to close the constraint menu, toggle visibility, reopen the constraint menu, and make the constraint. this takes a few seconds, but those add up,
a way to change visibility while in those functions would allow for a faster and more simple workflow, especially in large assembly's
kind regards,
Robin
