ALIGN TO EDGE WHEN ROTATING
It would be useful when using the rotate command during sketch mode to be able to align a sketch to an edge on the plane you are working on. Sometimes the angle of an edge is unknown to the user so it makes it difficult to place a sketch in relation to that edge.
The attached image shows an example where I have attempted to align text to an edge of a model. I know it is possible to project the edge and then align it to the curve but it would be simpler to have a check box in the rotate command box that said "align to edge" and then select the edge.
2 Comments
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
