Show only
Search instead for
Are you trying to add the tolerance to the model or the drawing?
In the model you should be able to do this already. If you right click on the fillet in the bowser and select Show Dimensions you should them be able to right click on the fillet radius select Dimension Properties and add a tolerance
I'm talking about the model I see now how it can be done. However, when you call the fillet command, and you type in the number, I don't have the option to set the tolerance. You have to put in the nominal size, and then go back and set the tolerance later. Shouldn't you be able to set the tolerance from the start?
rchiccarine, I suggest you edit your original idea as jletcher have pointed out, otherwise people will simply ignore your idea. it is a good idea but it could possibly go a lot further as you should have the option to add a tolerance to ALL feature dimension in thier respective dialogs not just through the show dimentions after the event
That's a goiod suggestion. I didn't really present the idea well. But, it's such a radical change to the original post, I think, I'll start a new thread.
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes.
We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found
that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know.
- Inventor product team (Inv.idea review)
