It would be great if in the iLogic rule editor within the model tab if you could add "Key Parameters" as an option where the "Model Parameter" / "Reference Parameter" / "User Parameters" are found. This would enhance the rule editor a lot and give you another option to find the parameter you want to get or set.
(We are Factory Design Suite Users, so use Key Parameter in all of our assets. This would make writing those rules a little bit easier)
My idea is to add in somewhere up here....
