Show only
Search instead for
To keep parameters screen organized and tidy, it would be nice to have the option to insert row, just as you can in Excel. And or the ability to move a row up and down in the screen.
I have also always wanted to be able to arrange the user parameters into a specific order, either by drag & drop, or by selecting specific row(s) and using a 'move up' or 'move down' control.
Using the 'Filter' control to narrow it down to only the 'Renamed' ones has been very helpful, and the ability to arrange the contents of the Parameters dialog by their column values (such as the parameter names) can be helpful too, but usually not the way I want it. So, what I usually do instead is create a quickie iLogic Form, then drag just the Parameters I want to deal with over into it, then arrange them the way I want them. And if there are a lot of parts with the same important, 'named' parameters, I may choose to convert the 'local' (internal) iLogic Form into a 'global' (external) iLogic Form, that way there is one form for all similar designs, stored in a neutral location.
