Add a "Negative" radius for clearance
When providing for clearance in corners, we are sometimes required to provide for a "negative" corner radius.  Presently, Inventor does not allow for this and we have to use other means to place this feature (new sketch and extrude, ifeatures...etc).  I would like to be able to either enter a negative value for the fillet, or have an option in the fillet command to run the fillet the opposite direction.  In the image below, I show the "negative" fillet.
Kirk
31 Comments
stuartmp
That's a awesome idea karthur1 I can see how this would save time.
stuartmp
Great Idea, even though I think its a duplicate request, I would love to see this feature.
A verry good sugestion.
I dont care about the semantics; Put it in the filet tool and give us a button were we can select negativ or positif.
dan_szymanski
Status changed to: Accepted
Accepted idea [468]. Thanks!
A smal step for men a Hughes step for Autodesk Smiley Very Happy
Spoiler
dan_szymanski
Status changed to: Gathering Support
Hello Delmeco, I am setting this Idea as a Duplicate of http://forums.autodesk.com/t5/inventor-ideastation/add-a-quot-negative-quot-radius-for-clearance/idi... Please be sure to cast your kudo to the master idea.  Thanks! -Dan
Guys, if this would also work on a turned part (say, undercut corner in the shoulder between larger and smaller diameter), that would be fantastic.
Of course that doesn't simplify making a square groove undercut, but a radius undercut is effective enough and it totally belongs in the fillet tool.
nate.goss
Observer
Some possible solutions for this idea are currently under discussion on the NDA based Inventor Feedback/Beta forums. If you’re not already a member of the Inventor Feedback/beta program then click this link to apply – http://bit.ly/InventorBeta
Dear Autodesk Inventor,
We have Command for Fillet and Corner round the Circle with center in
I need, we need, pls  build the Command for Fillet and Corner round the Circle out with center at corner (image below)
Marco.Takx
This idea is already posted on the idea station.
Negative Radius
dan_szymanski
This idea has been implemented within Autodesk Inventor 2019. Special thanks to everyone who cast a vote for it.  A new "Inverted Fillet" option can be set via the Type drop down when creating or editing a Fillet.
