accessing part drawing
Enable user to access part drawing directly in assembly's browser. Why should you have to go to the model first?
4 Comments
swalton
Currently you can get to a part/subassembly drawing from an assembly browser without opening the part/subassembly model.  Do you want that tool to be easier to discover?
Or do you want to open a part/subassembly drawing from the parent assembly drawing?
How? My drop down menu does not have this capability>
swalton
Select the component in the model browser or in the graphics window.
Press the right mouse button and expand out the "components" (I think... I don't have Inventor open right now) sub menu.  I think it is in the same sub menu as the promote/demote commands.  The command is "Open Drawing"
There are some limitations.
  • The drawing needs to be saved in the same folder as the part/assembly.
  • The drawing needs to have the same filename as the part/assembly.
    • This means that you must use the one-drawing-per-part/assembly workflow.  Detailing several parts in the same drawing file will not work.
I added the Open Drawing command to all the various assembly radial menus.  Others have made custom keyboard shortcuts.
Thank you very much for the info. It takes two drop down menus but I can at least get to some drawings.
Lou Totilas
Manufacturing Engineer
[cid:2415ca74-598a-4498-ad72-4c765d3e1592]
AGI NECO
9364 North 45th Street, Omaha, NE 68152
P: 402.453.6912 ext. 3230 F: 402.502.1709 E: [email protected]
necodryers.com<> aggrowth.com<>
LinkedIn<> Facebook<> Twitter<> YouTube<>
This e-mail may be privileged and/or confidential, and the sender does not waive any related rights and obligations.
Any distribution use or copying of this e-mail or the information it contains by other than an intended recipient is unauthorized.
If you received this e-mail in error, please advise me (by return e-mail or otherwise) immediately.
