Hi all,
I was looking in inventor a way to find zero force members in the frame analysis.
something like this.
But when I tried it in Inventor, I always get a force in the (zero force member) white beam.
Anyone an idea?
Solved by admaiora. Go to Solution.
Solved by johnsonshiue. Go to Solution.
I am trying to see the image on mobile device - so I might be missing something.
Do you have Gravity defined?
Gravity would induce a force on all parts.
Can you Attach your files here?
i am looking for a way to attach the files.
i cannot upload a zip file in the attachments
Hi! The zero-force member only exists if there is no deformation (ideal). When there is deformation, all members bear load.
Many thanks!
Yes, I agree totally with @johnsonshiue
You can release the moment in that beam to zero, but not stress.
Admaiora
