Xml Import Issues
Xml Import Issues
Xml Import Issues
I'm currently working on importing an xml document into a drawing which in turn will drive what notes are visible.
It work's great when the xml document is in the correct location but as others look at the drawings it's coming up with an error message saying that it cannot find the xml. Is there any way to hide this message / stop it appearing if the xml document isn't available ?
Thanks in advance 🙂
Anyone got any idea's ??,
This is the code i have so far:
SyntaxEditor Code Snippet
iLogicVb.Automation.ParametersXmlLoad(ThisDoc.Document, ThisDoc.Path + "\" + Left(ThisDoc.FileName(False),4) + "-5.5-02_" + "DATA-SHEET" + "_PARAMETERS" + ".xml")
Just need something that says if file unavalible no error message ?
Cracked it 🙂
If System.IO.File.Exists(ThisDoc.Path + "\" + Left(ThisDoc.FileName(False),4) + "-5.5-02_" + "DATA-SHEET" + "_PARAMETERS" + ".xml") Then
 Else
End If
