Wrong thumbnails for Inventor and AutoCad files
Hello all
I have gotten a quite annoying issue lately.
My inventor and AutoCad files seems to have gotten messed up thumbnails... Picture below shows how a working folder migh appear...
Both part and assembly files has the same icon..
This goes for everywhere i save a file, both on desktop, working folder etc.
Does anyone have same experience ? And does anyone know how to fix this ?
I am running a newly updated 2015 proffessional, but the issue appeared late on the 2014 version.
An update to latest version did not fix the problem in other words
Paul-Mason
Looks like you in "DETAIL VIEW"
As opposed to "LARGE ICON"
You may have to change all the sub-files one at a time if  navigating to C:\Users\**you name here ** in the LEFT-HAND pain of Windows Explorer and RMB - properties and :-
then Apply or OK
Some time ago I had a similar problem where no matter what I did I could not get a preview, in that case it was caused by Avequest Fix It Utilities, so if you've got that on your system then I'm afraid you screwed unless you remove it an put something like Norton on instead.
Inventor 2026 Pro
HP Z4 G4 workstation
Xeon
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group and myself
Hello
I am not quite sure that is my problem... neither have I installed the program you mention.
I was expecting my files to show as on the picture above (taken from internet), and not like mine do...
I cant see this having anything with detail view or similar...
All my files have the same icon... assemblies and parts... .drawings etc... That is my problem
Paul-Mason
Are you seeing this from with in the Inventor min-browser when opening a file as well ?
Have you OPENED any of the files yet ??
I note you say latest version what version were/did you using/use to create these files ???
Did/Have you MIGRATED these files to the most recent versions of Inventor ????
Inventor 2026 Pro
Xeon
- My files look the same no matter from where i look at them... both browser and opening files.. also files stored on my desktop appear the same way
Yes, i have used Inventor as normal
- Most files were originally created in 2014.. the issues started while using 2014. An uninstallment of this and fresh install of 2015 did not solve the issues
- Files are migrated to 2015 version. We have 4 other users which does not have this issues
