Inventor Forum
Wrong drill with tapped wizard.
6 REPLIES 6
452 Views, 6 Replies
I know there are many of these topic.
But instead of to change the thread spreadsheet, could it not be possible to get the inventor to read the column with tap drills "Basic"??
http://screencast.com/t/6l5tEb6arj
Thanks in advance
Jacob
Denmark
6 REPLIES 6
mcgyvr
I'm not sure what your question is about..
Inventor does use that column..
wispoxy
Check the ratio difference, what is it reading? What makes you think it's not using basic?
in reply to: mcgyvr
When I draw a thread ex. M3 look at the column O, and it gives me a wrong dia when I drag the file into my CAM system.
http://screencast.com/t/NpNXW0RHu
Jacob
I would really like to read the column with "Tap Drill"
mcgyvr
@Anonymous wrote:
When I draw a thread ex. M3 look at the column O, and it gives me a wrong dia when I drag the file into my CAMsystem.
Now your question makes more sense..
Simply edit the document settings to use tap drill instead of minor diameter..
smokes2998
in reply to: mcgyvr
Be warned the tapped drill diameter does not vary with depth. Always refer to the ISO or ASME or machinist hand book before cutting.
