I know there are many of these topic.
But instead of to change the thread spreadsheet, could it not be possible to get the inventor to read the column with tap drills "Basic"??
http://screencast.com/t/6l5tEb6arj
Thanks in advance
Jacob
Denmark
Solved by mcgyvr. Go to Solution.
I'm not sure what your question is about..
Inventor does use that column..
When I draw a thread ex. M3 look at the column O, and it gives me a wrong dia when I drag the file into my CAM system.
http://screencast.com/t/NpNXW0RHu
Jacob
@Anonymous wrote:
When I draw a thread ex. M3 look at the column O, and it gives me a wrong dia when I drag the file into my CAMsystem.
I would really like to read the column with "Tap Drill"
Now your question makes more sense..
Simply edit the document settings to use tap drill instead of minor diameter..
