Hello everybody,
This is my first post on this forum, so i hope i'm doing his the right way.
In a Assembly that i want to check in to Vault including children there is a assembly who isn't actually there.
See screenshots:
The model browser shows which sub-assembly's are inside this assembly.
(This is the actual right situation.)
The Vault browser says there's a extra assembly, but it actually isn't.
Can somebody tell me how to delete this T29 sub-assembly from this assembly?
For now Thank You!
Solved by johnsonshiue. Go to Solution.
@Anonymous
Welcome to the forum! Your post looks great to me! You included images, and described your problem nicely. The only thing I might add is the version of the software that you are using. Sometimes that helps us to figure out what is going on.
So,... I'm Chris, the Community Manager for Product Design & Manufacturing. I monitor this forum as well as Vault, Fusion and several others. If you need help with anything Community related, @tag me like I did with your name at the top of this post. You can do that with any username to get their attention.
On this question: Is the T29 subb-assembly embedded in anyway in one of your other sub-assemblies? Can you look at this assembly in your Vault browser, and see if it shows up in the "Uses" tab? Also, in Inventor, on the Vault tab like in your second image, select the sub-assembly, right mouse click and choose Find in Window,... see where that takes you.
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
To add onto what Chris said, if the assembly was already checked into Vault with T29 in it and then T29 got deleted from the assembly, Vault will remember that. One of the perks of Vault is it remembers that history, one of the bummers is also that it remembers that history.
Hi! This behavior may not be Vault related. I believe if you unload Vault Add-In, the same behavior should be there. Two possibilities. 1) The assembly has a substitute LOD referencing the ghost subassembly. 2) There is a corrupted reference.
If possible, please share the files here. Forum experts can help take a look and understand the behavior better.
Many thanks!
Hi! Like I mentioned earlier, the iam file is probably corrupted. To get rid of the corruption, you may need to select the components within the assembly and demote them to a new subassembly. Use this new subassembly instead. The issue here is that the iProperties and other attributes within the old assembly may not carry over. You will need to add them back manually.
Many thanks!
