Working with parameters
bronc3buster842001
bronc3buster842001
How to use in parameters with unitless parameters and not get screwed up results.
From what I have figured out is unitless is actually in cm.
The parameter conv is the conversion to make lengthofthread and numofcoils work together. Seems there should be an easier way to make the two work together. so basically for every inch of lengthofthread, numofcoils needs multiplied by 10.
So am I missing something on how to take a in parameter and a unitless parameter and make them work without the extra parameterUntitled.png
Your 'lengthofthread' parameter is in inches and the 'conv' parameter is defined as unitless. The formula for 'conv' results in 'conv' being in inches rather than unitless. The easiest way to make it work would be to define 'conv = lengthofthread * 10ul / 1 in'. It's either as simple as that, or I don't understand your question correctly.
bronc3buster842001
Ok that works. Just didnt know to divide by 1in again
Frederick_Law
Just follow the equation:
NumberCoil (ul) = CoilLength (in) / pitch (in)
Don't need to convert units.
SBix26
As others pointed out, the issue is with the units.  Here's possibly the easiest way to resolve this:
The units of your pitch parameter should really be unitless/inch (threads per inch, right?).  That makes the units come out just right, without messy conversion stuff involved.
Sam B
Inventor Pro 2019.1.2 | Windows 7 SP1
LinkedIn
bronc3buster842001
See I didnt know you could do that. I was under the impression the units had to be one or the otherI really just started playing around with using parameters..
johnsonshiue
Hi! Yes, you can combine units in an expression. Unit in parameter is treated like part of the equation. All parameters in Inventor require a unit (or unitless unit).
Many thanks!
Software Test Engineer
