Workgroup Search Path issue
rh8mpo
rh8mpo
We have multiple CAD stations connected to a server and use the Workgroup Search paths to load up common parts in assemblies.
However, we have 1 PC where this system is not automatically loading up the paths - it generally navigates to the correct folder, but then prompts the user to select the file.
Any suggestions for resolving this issue?
Neil_Cross
Has that PC definitely got the right project file enabled/ticked? Can you copy the project file from one PC that works and overwrite it on the one that doesn't?
Roelof.Feijen
Do al CAD stations use the same project file?
If not. It might have something to do with the Using Unique File Name setting.
Roelof Feijen
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
rh8mpo
Thank-you for the responses - we've tracked down the issue to some corrupted files on the affected PC, which is why Inventor picked-up the right location for the file, but didn't automatically load it.
Once those corrupted files had been overwritten with a good version the issue was resolved.
